high amperage draw on new motor
Discussion in 'General Electronics Chat' started by natox, Jul 8, 2013.
  1. natox
    Jul 4, 2013
    I have a 15 horsepower motor hooked up to 3 phase 480 and it's supposed to be drawing 16 to 17 amps it's drawing 29 and its overheating its controled by relays and goes through a contactor and is on a 30 amp breaker and I don't know what is causing it.do I need to put it on a VFD? Its for a blower in a car wash and it never had anything else before on the motor
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    Is it a dual voltage motor? do you have it wired for 480V?
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    Was this motor replaced because the existing motor failed?
  4. Duane P Wetick
    Apr 23, 2009
    408
    19
    I'm almost certain that you have it wired for low voltage when it should be wired for high voltage...Re-do the connections at once for High Voltage! You may have a dual voltage starter, ie: Low Voltage Start...High Voltage Run.
    Cheers, DPW [Everything has limitations...and I hate limitations.]
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    Me too, but I have the uncanny power of changing root cause by expressing absolute certainty. So I don't.
    Metalmann and #12 like this.
  6. natox
    Jul 4, 2013
    it is dual voltage 208 & 460 its got 12 different leads for different combinations of hookups for delta run or delta start wye start to Delta run. I'm a state certified journeymen electrician an inside wireman with the International Brotherhood of Electrical Workers I'm confident in my abilities to know that its hooked up correctly(not said in athe one who replaced was doing the exact same thing and tripping the breaker
  7. gerty
    Aug 30, 2007
    1,154
    304
    Have you tried running it unloaded?
  8. Dodgydave
    Jun 22, 2012
    5,154
    772
    Ok lets have the pictures of it then and a model number..
  9. natox
    Jul 4, 2013
    Havent tried to run it unloaded but its only a mechanical blower and I can spin it with my hand but I will take pictures soon as I get back to that site thank you all for your help
  10. crutschow
    Mar 14, 2008
    13,501
    3,375
    Perhaps you somehow lost a phase. Have you checked the current in all three phases?
  11. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    So, how is the motor started, across the line?
  12. BillB3857
    Feb 28, 2009
    2,402
    348
    Have any shrounds, etc. been removed from the blower and not replaced. An increase in the intake size of a blower can cause higher loads on the motor. Listen to the motor on a vacuum cleaner when you restrict the air flow. Motor unloads and speeds up.
  13. natox
    Jul 4, 2013
    no shrouds have been removed from it the old motor was doing the exact same thing figured and decided to replace it
  14. gerty
    Aug 30, 2007
    1,154
    304
  15. shortbus
    Sep 30, 2009
    4,095
    1,685
    gerty likes this.
