Hifonics bxi 1606d burnt resistors???
Discussion in 'The Projects Forum' started by gadgeteer123, Jun 24, 2009.
  1. gadgeteer123
    Jun 24, 2009
    I have a Hifonics BXi 1606D Super class d amp, that has roughly about 10 blown/burnt resistors, i'm capable of replacing these, i just have no clue on what i need to order, the numbers next to the resistors are-R25E1, R26E1, R27E1, R28E1, R29E1, R30E1, R25E, R35E, R26E, and one that i cannot read, and a couple of the mosfets are cracked right by these resistors. so could you help me figure out which parts i need.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Do you have the schematic?
    The resistors are probably broken due to malfunctioning of the mosfets.
    Greetings,
    Bertus
  3. gadgeteer123
    Jun 24, 2009
    well i know its the mosfets cuz theres a couple mosfets that are cracked, and i don't have shematics.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That presents a real challenge. The component values are on the schematic, keyed to the part designators.
    If the damage is all in one channel, you may be able to find the complimentary part on the other side and get their values by measurement. The FET's may be standard and have good numbers on the case.
    Of course, there may be more damage further back in the driver IC. You could get lucky, but class D amps usually need a meter and oscilloscope to troubleshoot.
  5. gadgeteer123
    Jun 24, 2009
    well its a mono amp so idn.
