hierarchical design in vlsi system
Discussion in 'General Electronics Chat' started by vead, May 19, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    hierarchical design is used to reduce complexity of circuit by chip designer
    mainly three approach are used
    1)modularity
    2)regularity
    3)locality
    1)modularity - submodule have well defined function and Interface
    2)regularity - big system divide into similar submodule
    Q- I have searched on goggle BUT I don't understand I am looking real example for modularity and regularity
    does anyone can help with simple example
  2. vead
    Nov 24, 2011
    621
    8
    please help me
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    standardization of gate circuits is one expample of modularity. and if you look at the layout of ram or rom designs, they are very regular. that helps to keep the speed constant across the chip.
  4. vead
    Nov 24, 2011
    621
    8
    thanks for reply but but can you explain little bit
  5. vead
    Nov 24, 2011
    621
    8
    please someone can help me I just want example
  6. Brownout
    Jan 10, 2012
    2,375
    998
    Thins of an SOC--System On a Chip-- it has a processor and several peripherals such as UART, SPI, etc. The processor and individual peripherals are all modules. They are developed individually, and then integrated into a system.
    vead likes this.
  7. vead
    Nov 24, 2011
    621
    8
    I know that but what is modularity, regularity ,locality in design
  8. Brownout
    Jan 10, 2012
    2,375
    998
    I just explained modularity.
  9. vead
    Nov 24, 2011
    621
    8
    do you know about regularity ,locality
  10. Brownout
    Jan 10, 2012
    2,375
    998
    From where are you getting these terms?
    reg·u·lar·i·ty
    noun \ˌre-gyə-ˈla-rə-tē also ˌrā-\
    plural reg·u·lar·i·ties
    : the quality or state of being regular
    : something that is regular
    lo·cal·i·ty
    noun \lō-ˈka-lə-tē\ a particular place or area
  11. vead
    Nov 24, 2011
    621
    8
    this is exam question and I don't understand
  12. vead
    Nov 24, 2011
    621
    8
    look at this statement
    Regularity means that the hierarchical decomposition of a large system should result in not only simple, but also similar blocks, as much as possible.
    The concept of locality also ensures that connections are mostly between neighboring modules,
    can anyone give example for this statement for my understanding
  13. Brownout
    Jan 10, 2012
    2,375
    998
    eg.: locating cache memory close to a processor on the die so that connections between processor and cache memory are made with short wires.
    I have no idea about the other one.
