Hiding a head unit in a corsa
Discussion in 'The Projects Forum' started by Adamhumbug, Mar 5, 2014.
Thread Status:
Not open for further replies.
  1. Adamhumbug
    Mar 5, 2014
    Hi all, I will start by saying I know very little about electronics so please be as basic as you can be with your kind responses. Also when referring to products if you could give an example of what I need that would also be appreciated.
    I am mounting a double din head unit into my vauxhall corsa and it is quite an expensive unit.
    My "plan" is to hide the head unit behind the rest of the centre console and when the key is inverted, the head unit will rise up and may have to move forward slightly so that it is flush with the hole that will be cut.
    I know this is slightly leaving the forum boundaries but I would also need this to be solid so I might need to make mount this in some sort of Box/guide so that it does not move around when in use.
    What I would like is a guide in how I could make this happen.
    Many thanks
    Adam
  2. wayneh
    Sep 9, 2010
    12,382
    3,241
    Greek to me. You may get more and better feedback if you provide a photo or two, and maybe more detail about what you want to do.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
