HID bootloader is good or ICSP for PIC controller
Discussion in 'The Projects Forum' started by embpic, Jun 23, 2014.
  1. embpic
    May 29, 2013
    187
    i want to know that whether HID bootloader is or ICSP. As i see HID bootloder is very simple and don't need any IC in between like serial bootloader and even it need any programmer.
    so my basic question is is HID bootloader is good?
  2. embpic
    May 29, 2013
    187
    any use this??
  3. tshuck
    Oct 18, 2012
    3,531
    675
    HID being an enumerated USB device to transfer data to/from the bootloader?
    Yes, that can be good.
  4. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Using a USB bootloader means there is a pre-loaded and constant program in a portion of a device, and you can change the rest of the program without any special hardware by connecting to a PC or similar device.
    Of course, you need a dedicated programmer to get the bootloader code into your device in the first place, or you buy a chip with that program pre-loaded.
    They are useful for inexpensive educational platforms to save the end used the expense of the programmer. They are also useful for user or field updates of commercial devices.
    Neither is better, one may be more suited to your needs.
  5. embpic
    May 29, 2013
    187
    which kinda restriction on the flash and other part of controller when i use HID controller.
