HID Ballast
Discussion in 'General Electronics Chat' started by R!f@@, Mar 22, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,792
    771
    See the Picture
    I have the bulb, see the attached pdf.
    It has 3 pins in the ballast. I like to use this in my bench :D
    Any clue on how to drive this. I know it uses 12V cause I have seen it in cars.
    Wht I think is ballast uses 2 pins for Voltage, I just dunno what the third is for. Is it a PWM or pulse or just the ON pin or sumthin.
    Any body has any Ideas.
  2. #12
    Nov 30, 2010
    16,705
    7,355
    If there is going to be a pulse, it will be a starting pulse to "strike" the arc.
    I see 2 wires to the socket, but I can't see how the 12v gets to the module.
    Maybe it has metal in a screw well and that's the ground?
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    No no.. the socket is for the bulb.
    Actually the photo does not show the connector in the ballast ( the black box filled with resin )
    It has 3 pin connector.
  4. #12
    Nov 30, 2010
    16,705
    7,355
    3 wires in a 12 volt system is not normal.
    can I see a photo?
  5. spinnaker
    Oct 29, 2009
    5,102
    1,190
    R!f@@ likes this.
  6. R!f@@
    Apr 2, 2009
    8,792
    771
  7. spinnaker
    Oct 29, 2009
    5,102
    1,190
    See my post above I think you will need an ignitor.
  8. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Oops maybe not because it looks like the ignitor is what connects to the lamp.
  9. R!f@@
    Apr 2, 2009
    8,792
    771
    Crap !!
    So I have the Ignitor...?
    Wonder where the heck is the Ballast ?
    Guess I have to go diving again.
  10. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Don't think so. Look at your pic and the one I posted.
    I think it might be a relay wire. Check this post.
    http://answers.yahoo.com/question/index?qid=20101004154647AAOnSQd
    Or maybe you do have an ignitor after looking again.
    Why don't you post the words on the device. Looks like it might be German.
  11. spinnaker
    Oct 29, 2009
    5,102
    1,190
    If I am reading it right it says
    nur mit lampe betreiben
    google translate says
    Only operate lamp
  12. spinnaker
    Oct 29, 2009
    5,102
    1,190
  13. BSomer
    Member
    Dec 28, 2011
    433
    106
    Just taking a jab at it... Could it be that your three pins are ground, low beam, and high beam???
  14. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Already solved he has an ignitor not a ballest. Zündgerät is ignitor in German.
  15. BSomer
    Member
    Dec 28, 2011
    433
    106
    oh. okay then. :)
  16. t06afre
    May 11, 2009
    5,939
    1,222
    The part you are looking for may be looking like this
  17. R!f@@
    Apr 2, 2009
    8,792
    771
    Hot digidydo !
    I remember one of those in the junk.
  18. t06afre
    May 11, 2009
    5,939
    1,222
    It may look somewhat diferent depending on which car you took it from. AL Bosch make OEM variants of this unit. Each car will two modules. Look for the high voltage symbol
  19. R!f@@
    Apr 2, 2009
    8,792
    771
    I was hunting for gopal's sink and look what I found
    Now I need to find the connections :D
    I believe this is the D2S unit as it states on the back 1200V/DC/85VAC 35W max.
    This thing has an infinion uC and a stepper driver... What the hack are they for ?
  20. R!f@@
    Apr 2, 2009
    8,792
    771
    Ok..tonight, it's either light or me or a hammering.
