HI-TECH C Compiler v9.63 code converting to MikroC Pro
Discussion in 'Homework Help' started by Chritoph8r, May 22, 2010.
  1. Chritoph8r
    Jan 19, 2010
    33
    Hi Again I'm trying to built LC METER .my Friend (here) give
    me a 90% accurate LC meter Project but the problem is the code
    is created in HI-TECH C Compiler v9.63, I want to compile it in
    MikroC Pro. which I'm comfortable to use.
    here the code that make me thinking twice on how to convert:
    ISSUE: 1
    __CONFIG(HS & WDTDIS & PWRTEN & BOREN); <<---- __config
    #define LC_select RB0 //L or C select (from DPDT switch) <<----
    #define lc_tris() TRISB0 = 1 //as input
    #define add_ccal() RC0 = 1 //relay on
    #define remove_ccal() RC0 = 0 //relay off
    #define relay_tris() TRISC0 = 0 //as output to drive the relay coil
    Q1. I want to know what is the equal function to MikroC Pro of __CONFiG?
    Q2. (RB0) WHICH ONE is right to use PORTB.B0 or PORTB.RB0 or PORTB.F1 ?
    all of them working properly when I'd Compile without generating Error.
    Q3. (TRISB) WHICH ONE is right to use TRISB.B0 or TRISB.RB0 or TRISB.F1 ?
    ISSUE: 2
    void initialize(void)
    //setup comparator
    CMCON = 0b00000101;
    TRISA = 0b11001111;
    //setup timer0 for frequency counter
    T0CS = 1; //Transition on T0CKI pin
    T0SE = 1; //Increment on high-to-low transition on T0CKI pin
    PSA = 0; //Prescaler is assigned to the Timer0 module
    PS2 = 1; //PS2:pS0 -> Prescaler Rate = divide by 256
    PS1 = 1;
    PS0 = 1;
    //initialize 3310 lcd
    lcd_init();
    lcd_clear();
    //others
    lc_tris();
    relay_tris();
    RBPU = 0; // enable portB internal pullup
    Q1. (T0CS,T0SE,PSA,PS2,PS1,PS0) WHICH ONE is right to use?
    example: T0CON.T0CS, PORTA.T0CS , TRISA.T0CS, OPTION_REG.T0CS.... whatKingOfRegister.T0CS ?
    Q2. (RBPU = 0;) is this portb=0?
