HI-TECH C and __delay_ms
Discussion in 'Programmer's Corner' started by trennonix, Jun 12, 2009.
  1. trennonix
    Jun 6, 2009
    I'm trynig the __delay_ms() function in hi-tech c lite edition
    but i always get a warning about "implicit signed to unsigned conversion"
    so the program runs as if the delay function was never written
    this is the code:
    #include​
    <htc.h>
    int​
    _XTAL_FREQ=4000000;
    unsigned​
    long time=200;
    void​
    main​
    void)
    TRISB=0;
    while (1){
    RB0=1;
    __delay_ms(time);
    RB0=0;
    __delay_ms(time);
    tried to add the numbers directly into the function without declaring a variable, but i still got the same error
    tried "(unsigned long)value" same thing :S
    Any ideas? thanks a lot
    btw i'm using the latest compiler (downloaded 3 days ago) for 10\12\16 family lite edition
    running in Hi-Tide IDE also latest version
  2. Mark44
    Nov 26, 2007
    626
    What does the protype for __delay_ms() look like? Presumably it's in the header file htc.h. You're passing an unsigned long in your call to this function, and very likely it is expecting a different type. The exact error would also be helpful.
    Here is your code, formatted for better readability:
    Code ( (Unknown Language)):
    1.
    2. #include <htc.h>
    3.
    4. int _XTAL_FREQ=4000000;
    5.
    6. unsigned long time=200;
    7.
    8. void main(void)
    9. {
    10.   TRISB=0;
    11.   while (1)
    12.   {
    13.      RB0=1;
    14.      __delay_ms(time);
    15.      RB0=0;
    16.      __delay_ms(time);
    17.   }
    18.
    19. }
    20.
  3. juninho
    Aug 1, 2009
    Look at this:
    #include <htc.h>
    unsigned long _XTAL_FREQ=4000000;
    void vdelay_ms(int from);
    int time=200;
    void main(void)
    PORTB=0;
    TRISB=0;
    while (1)
    RB0=1;
    vdelay_ms(time);
    RB0=0;
    vdelay_ms(time);
    unsigned int countertmp;
    countertmp=0;
    while (countertmp<from){
    __delay_ms(1);
    countertmp++;
