Hi,photocouple driver relay,is it safe?
Discussion in 'General Electronics Chat' started by rodbare, Jan 15, 2012.
  1. rodbare
    May 17, 2008
    I want to driver relay(G5V-2) with TLP523,is it safe?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Wich version of the relais are you planning to use?
    You must use a protection diode, cathode to the + and anode to the transistor, to protect the transistor from the back EMF of the relais.
    Bertus
  3. rodbare
    May 17, 2008
    ok !
    I will use g5v-2.
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Do you want to use the standard or high sensitivity relais?
    What voltage is the relais?
    The standard relais uses 100mA at 5 Volts.
    The TLP can switch 150 mA absolute maximum.
    Bertus
    PS I have attached the both datasheets.
