Hi, may i request a 1.2V nimh solar battery FLASHING charger ?
TYYang
Joined Apr 3, 2015
18
I need the circuit....I find and test a lot circuit from online, but i still unable to get a proper solar 1.2V LED monitoring battery charging circuit. I hope someone help me solve my problem, thank you very much
my solar panel is around 3-8V input
rechargeable battery AA/AAA 1200mah/3000mah
Denesius
Joined Feb 5, 2014
124
I'm not sure what you mean by 'monitoring', but I think you're looking at converting the solar output into battery charging current
There are a number of switching buck regulators that can do this, with a minimal component count. A cheap regulator is the LM2576-Adj (find data sheet here: http://www.ti.com/lit/ds/symlink/lm2576.pdf). You can set it up to convert your solar panel output down to a steady 1.20-1.25 volts (from 3-8 volts), and the output can be as much as 1 amp/hour (assuming your solar panel can output that much), which would charge your batteries nicely
TYYang
Joined Apr 3, 2015
18
Actually i wish to have a circuit which can show the charging status of battery.
For example:
1) fully charge - LED off, charging - LED on
or
2) fully charge - Red LED on, charging- Green LED on
takao21203
Joined Apr 28, 2012
3,702
what can I say? o_O:confused:
