Hi I want to measure the oil content and moisture to the skin.
Discussion in 'The Projects Forum' started by lsh1309, Jan 11, 2016.
  1. lsh1309
    Jan 11, 2016
    I use this chip, the AD5933 chip found.
    But I do not know how to spend the chip yet.
    I do not know've also data sheet.
    Can you ever tell if circuits or data associated with this chip?
  2. SLK001
    Nov 29, 2011
    849
    242
    What is the theory of your idea?
  3. driveman
    Jan 11, 2016
    isn't oil an insulator?
  4. GopherT
    Nov 23, 2012
    6,303
    4,020
    Why yes it is. How can you take advantage of that?
  5. hp1729
    Nov 23, 2015
    2,087
    232
    You need a data sheet?
  6. lsh1309
    Jan 11, 2016
    I have AD5933 datasheet
    What I wonder is a circuit choreography of ad5933.
    i saw ad5933 datasheet. but i don't undertstand that
  7. hp1729
    Nov 23, 2015
    2,087
    232
    That is a very complicated IC.
  8. hp1729
    Nov 23, 2015
    2,087
    232
    Impedance at different frequencies? That seems to be what the AD5933 is designed for.
  9. GopherT
    Nov 23, 2012
    6,303
    4,020
    I was thinking the same but apparently some studies were done back in the 1950s and it seems there is a lot of variability from person to person but not much variability in one person over time. Therefore, it would be difficult to calibrate a meter for any small variability in skin conditions without having a baseline for each individual.
    http://www.nature.com/jid/journal/v34/n5/full/jid196052a.html
  10. hp1729
    Nov 23, 2015
    2,087
    232
    That would seem to make it complicated
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    the chip is ADC itself.
    What are you trying to solve?
  12. kubeek
    Sep 20, 2005
    4,687
    805
    The chip is NOT an ADC, it has an ADC built into it with lot of additional circuitry. Rritesh, why don´t you stick to threads that are at your level of expertise and stop posting irrelevant or incorrect replies? Lately you seem to have something to say to almost everything and everytime you are either talking about something completely different or not helping at all.
    spinnaker and RRITESH KAKKAR like this.
  13. DickCappels
    Aug 21, 2008
    2,758
    667
    Everything you need to know about the chip (what it is, how to use it, etc.) is at the link below.
    http://www.analog.com/en/search.html?q=AD5933
    Using this chip will almost certainly require some sort of microcontroller or computer.
