hi i want to create a flashing LED on a timer
Discussion in 'General Electronics Chat' started by ukash, Jan 22, 2010.
  1. ukash
    Jan 22, 2010
    13
    Hi there, basically im rubbish with working out electronics and i need your help, i can build circuits from a diagram, so i need some help creating a circuit which flashes an LED for 5 seconds, 1 flash per second if possible, then stays on permanently, until its switched off, the input will be 12v DC
    thank you
    A
  2. Bernard
    Aug 7, 2008
    4,238
    414
    Two 555s , could be one 556, A & B. A is one-shot, 5 sec , triggered once at power turn on by .1uF holding pin 2 low for fraction of a second. A output ,pin 3 , enables B for 5 sec, pin 4 high.Timing cap B pin 2, should be one uF, giving 1/10 sec flash after 9/10 off, repeats 5 times 'till A resets B; B beeing reset keeps LED on- we hope.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    When you say turned off, how is this supposed to work? Like a flip flop, or removal of power?
  4. ukash
    Jan 22, 2010
    13
    removal of power
