Hi i need help with my PCI16f84a Project.
Discussion in 'Embedded Systems and Microcontrollers' started by EE_Rocky, Nov 25, 2011.
  1. EE_Rocky
    Nov 25, 2011
    6
    ok i have aproject to my Embbeded class and i need to make aproject like a Temprature or Humidity sensor Using a pic16f84a if someone can help i will be very thankful please if you could give links or codes for the project and how to wire the circuit assosiated with it thanks .
  2. tgil
    May 18, 2011
    19
    Here's the approach: go to digikey.com and search for a temperature sensor. Once you find one that you can work with (you will probably want a through hole part if you are using a breadboard), download the datasheet. Almost all datasheets have an example circuit. The easiest way will be to use an analog sensor and just connect the output of the sensor to the ADC input on the PIC16F84A.
    Good Luck.
  3. John P
    Oct 14, 2008
    1,638
    225
    You'll need that good luck, because the PIC16F84A has no ADC inputs.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    You can find temp sensors with I2C outputs, then use a bit banging routine in the 16F84a
    Or an offboard ADC with I2C output, and hook the temp sensor to the ADC input, this would allow you to measure other analog levels as well, once you have the I2C bit-banging routine done.
    There are several I2C bit banging (software I2C) routines for the 84a for free around the net, both in assembly and C, so it depends on the language and compiler you are using to find that snippet.
    I wish schools would update from that processor to one with SPI, ADC, UART built in, much more could be learned, and more frustration could be issued as assignments that way.
  5. John P
    Oct 14, 2008
    1,638
    225
    Yes, they really are letting the kids down by making them use that old clunker.
    It's possible to read an analog sensor without any extra hardware except a capacitor, but since this is a school assignment I don't think I ought to give all the details.
  6. EE_Rocky
    Nov 25, 2011
    6
    well first of all thanks and it is acollege project for my embedded course
  7. EE_Rocky
    Nov 25, 2011
    6
    is there any schematic diagrams or something like that ?
  8. t06afre
    May 11, 2009
    5,939
    1,222
    Do you have to use the 16f84a, or can you use another PIC. Anyway since this is schoolwork. I suggest you go to your teacher. And say you need an ADC and a temperature sensor. I guess those parts have to come out of the school store. Then you do some piece of engineering. I am sure we can give your project a push in the correct direction. But do not expect us to just serve you a complete project with schematics and code on a silver plate.
  9. EE_Rocky
    Nov 25, 2011
    6
    yes i have to use pic16f84a and i written acode and drew adiagram but i just need to make sure it operate correctly so i will go and buy the items that i need
  10. t06afre
    May 11, 2009
    5,939
    1,222
  11. EE_Rocky
    Nov 25, 2011
    6
    thanks i will try that , my schematics is now with my partner if anything goes wrong i will post them here thanks alot
