Hi.I have a Pihsiang controller board that has a relay problem
Discussion in 'General Electronics Chat' started by KrTres, Mar 21, 2016.
  1. KrTres
    Mar 21, 2016
    Any help will be greatly appreciated.When the power to the relay on the controller board is off it looks like it is closed and when power is applied opens then when you pull the lever to start the motor the contacts don't close.If you push the contact and hold it closed it sends power to the motor ok then.Thanks
  2. SLK001
    Nov 29, 2011
    852
    243
    Did you apply enough choke? Maybe squirt some starting fluid into the carburetor until it starts?
  3. KrTres
    Mar 21, 2016
    Hi. This is a controller circuit board for a shoprider scooter.
