hi, https://dl-web.dropbox.com/get/EE/E...ions of Electrical Engineering.pdf?w=24b7629f
at page 63, question 232, how do i do the resistance calculation?
Hi thanks alot for the reply.Thank you for posting the sketch here.
First, you need to redraw the figure as you attempt to solve it. It may require redrawing it more than once. Second, when you redraw it, make the diagonal 6Ω as vertical.
Third, do you see any series or parallel combinations that might simplify the network? I see several. Redraw the network as you combine the combinations.
