Hello all i'm new to the forum but have been reading all of the interesting projects that members have been making.
I'm based over seas and in the HM forces, when I move back to the UK I plan to buy a large dog house and run. It basically has a run area with a sheltered and enclosed area for my dog to sleep, lie down in or plot against mankind.
Now, I plan on buying 2 tubular heaters:
http://www.amazon.co.uk/WHITE-TUBUL...UTF8&coliid=IDZOA87M8HELT&colid=2E2YM1JAY0RNK
I plan on installing them inside his enclosed area and then fitting a temperature sensor and fire alarm.
These will go back to a IP66 rated enclosure on the outside of the building, which will have a LED screen and keypad to set the inside temperature. Switches to activate/deactivate the systems and a float sensor on his water bowl which will report that the water is low and top it up.
There will be a piezo (sp?) buzzer inside the enclosure which will go off on a fire alarm trip or if the system loses power (by backup square battery).
Now, although this all sounds extravagant and a waste of resources, it's purely a project that when completed will hopefully of taught me about electronics and look pretty cool.
I've attached a rough sketch of what I hope it to look like:
I already have:
Good Soldering iron
Good Multimeter
Buzzer (12v)
Square battery connector
LCD Screen
3x Switches
4x Lights
1x LED Light strip (to illuminate box)
Plenty of copper plated/fiberglass PCB
Breadboard
Lots of jump wires
Flux pens
IP66 Rated Enclosure
Keypad
Limited knowledge of electronics, I have rewired a motorbike and fixed a couple of things but that is as far as i've been.
So, I ask you the knowing community, how 'do-able' is this project and what elements are required? Such as EPROM and chips etc.
Can anyone give me advice on where to start?
Your ideas, thoughts and suggestions are greatly appreciated.
John
I already have:
Good Soldering iron
Good Multimeter
Buzzer (12v)
LCD Screen
3x Switches
4x Lights
Breadboard
Lots of jump wires
Flux pens
Keypad
John
