hfe versus Beta
Discussion in 'Homework Help' started by Konstabel, Jan 31, 2008.
  1. Konstabel
    Thread Starter Active Member
    Jan 31, 2008
    52
    Can anyone please explain to me the difference between the beta value (Ic/Ib) and the hfe value found on a datasheet. I am trying to design a pnp switch and don't know which value to use in my calculations.
  2. mentaaal
    Oct 17, 2005
    451
    I think that beta is the current gain for a particular circuit. This depends on things like hfe and resistance values. Hfe is the forward current gain of the particular transistor and can vary from transistor to transistor.
  3. studiot
    Nov 9, 2007
    5,005
    515
    Firstly hfe is one of a suite of h parameters and refers only to the common emitter configuration. You can call it the AC current gain.
    All the h parameters are AC parameters.
    Lower case is used to denote small signal operation. (hfe)
    Upper case is used to denote large signal conditions. (hFE)
    Small signal means signal is not large enough to take the transistor where the characteristics are significantly changed.
    Large signal obviously does and is what you need for switching as the transistor will go from full off to full on.
    hFE is always less than hfe.
    Beta is a static (DC) parameter the DC current gain,which gives a rough idea of the ac gain, but is much easier to measure. It is what is indicated on simple transistor tester.
    thumb2 likes this.
  4. Konstabel
    Jan 31, 2008
    52
    Thanks for the answers.
    Just to make sure. Then when using a transistor as a on/of switch I will be using the beta value in my calculations?
  5. studiot
    Nov 9, 2007
    5,005
    515
    Don't know what you are calculating?
    When you use a transistor as a switch the gain (so long as it has some) doesn't usually enter into it.
    Beta and hfe are for analogue circuit calculations. When you use a transistor as a switch your first approcimation is
    Vout = zero (transistor off)
    or
    Vout = Vcc (transistor on)
    Important parameters are switching time (on and off) and Vcesat the saturated voltage between the collector and emitter, which determines the minimum low.
    In particular if operating the transistor in the saturation region (switching) the relationship
    Ic = beta times Ib
    Is not true.
    Use the equation
    Icsat = Vcc/(Rc + Re)
  6. Konstabel
    Jan 31, 2008
    52
    The calculations I am referring to is in designing the switch circuit when the resistor values are unknown but the base current is known.
    To use the formula you gave (Icsat = Vcc/(Re+Rb), why does it not take into calculation the Veb_sat value?
    Just to make sure, where is Vcc measured?
  7. studiot
    Nov 9, 2007
    5,005
    515
    I expect this is the analysis you are looking for.
