I am building a controller for my 110V Harbor Freight spotwelder and was looking for some advice. The controller will consist of a trigger/timing circuit, a current control circuit, and the spotwelder itself. I plan to put all the controller on the primary side of the spotwelder transformer because of the lower current values (110VAC, 15-20A house current) vice the higher current values on the secondary side. I have the timer circuit figured out but need advice on the best design for a dual opposing SCR or TRIAC controller circuit. I found this but the SCRs are rated at 16A.
http://www.electroschematics.com/wp-content/uploads/2013/02/SCR-Phase-Control-Dimmer-Schematic.jpg
I am concerned about the max current rating of the SCR, and would prefer a buffer for any transients and to lessen wear and tear on the components. Also, what kind of power values should I use for the components if I use this circuit?
I know that I could probably use a simple R/C circuit to control the gates of the SCRs with the resistor being variable, but am not sure how to design it myself. That why I am leaning towards the circuit I found. Any advice would be greatly appreciated.
