hey i need some help with connecting a thermocouple to an adc
Discussion in 'The Projects Forum' started by nnaselli, Feb 12, 2011.
  1. nnaselli
    Feb 12, 2011
    5
    hey i am trying to get a thermocouple to connect to ac adc to show temp on 7 segment displays and turn a heater on depending on the temperature. but i have no idea how to get the thermocouple to connect to the adc. anyone have any wiring diagrams to help me out.
  2. wayneh
    Sep 9, 2010
    12,362
    3,220
    You may find it easier to use a digital thermometer IC such as LM35, which outputs a voltage directly proportional to temperature. A thermocouple changes resistance with temperature, and you need circuitry to convert that to voltage, and making it linear can be a challenge. For simple thermostat applications, it's probably fine. But I really like the LM35!
  3. nnaselli
    Feb 12, 2011
    5
    thanks for the advice.can u tell me how to use the lm35 to an adc
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    What is the temperature range you want to measure?
    The LM35 will work from - 55 to + 150 °C.
    For the negative temperatures it needs a negative powersupply.
    Bertus
  5. nnaselli
    Feb 12, 2011
    5
    i need to measure from 0°F to +80°F
  6. wayneh
    Sep 9, 2010
    12,362
    3,220
    Well, you could use the LM34 (Faranheit), although it's harder to find than the LM35 (Celsius). The LM34 reads 0V at 0°F and 0.8V at 80°F. It might not be accurate right down at 0° if you power it only with a single supply. Read the datasheet - it'll answer all.
  7. nnaselli
    Feb 12, 2011
    5
    i could just convert F to C and use the lm35. because i just need to know when it dips below 70°F which is about 21°C. that is no problem just that i need help trying to get it to an adc to an 8051 microcontroller
  8. wayneh
    Sep 9, 2010
    12,362
    3,220
    Well, if your equipment can use the voltages directly from the LM35, eg 15-25°C = 0.15-0.25V, then you're all set. You just need to power the LM35. Also, I've had better luck when I load its output with a 220Ω resistor, at the meter end. Others here have not needed that, so you may want to just experiment. I also recommend using shielded cable if you need the sensor to be very far from the meter, more than a few feet.
