Hey Guys. Im working with Karnaugh Mapping and Digital Logic and need some help.
Discussion in 'Homework Help' started by DanRab, Jun 3, 2015.
  1. DanRab
    May 4, 2015
    8
    The problem was : Z(A, B, C, D) = ∑m(0,2,5,7,8,10,13,15) do the following: i) Represent the logic equation in a Karnaugh map. [4] ii) Determine the most simplified equation and implement the resulting circuit using basic logic gates. [5]
    I managed to simplify the logic into a karnaugh map and was left with the equation BD+B'D'.
    Im not sure on how to implement this with basic logic gates.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    You've gotten the harder part. Try writing out, in words, what the resulting expression means. This describes the logical interconnections for implementing the expression using gates.
    If you need more reading material, you can find some in the eBook.
    As an aside, BD+B'D' is not an equation - it needs an equals sign for that. Z = BD+B'D' is an equation.
  3. DanRab
    May 4, 2015
    8
    Thats great. thank you.
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    There's also the question of what it means to be "most simplified", something that few texts or instructors bother to recognize. This equation can be implemented using a single two-input standard logic gate, but that is probably not what is being asked for.
  5. shteii01
    Feb 19, 2010
    3,500
    511
    That does not sound right.
    You don't simplify logic into Karnaugh Map.
    You put the logic into the map, then use the map to simplify the logic. The map shows which parts of the logic you, the user, don't need.
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    Looking at his work, I think he did it the usual way. His word choice in the verbal description just made it seem backwards.
    But I sure do applaud him for showing his work in the original post!
