as far as i know, its the hex file that you burn into the uc and not the asm file. correct me if i am wrong. you can also manually convert the hex file into asm using the instruction set of the particular uc.
Dearest jpanhalt and beck, Actually I wanna burn it by MPLAB on a PIC16f628 but I couldn't thats why i asked you for a method to convert it to ASM as its easy for me, in addition i hope to see it in ASM format BUT if you wanna try, here the file you can download it and don't forget that i'll wait your feedback. Cheers guys
As was pointed out, if the hex file was written for an 16F628 and you are burning a 628 (not 628A), I believe you can load the hex file and burn directly.
If not, search for the appropriate disassembler. There are several.
John
MPLAB software does not directly burn software into your chip, rather it interfaces to a limited range of programmers and directs them to load the hex file and burn it into the chip.
Most programmers allow you to load the hex file and burn it into the PIC without running MPLAB.
If you really do need to disassemble your hex code so that you can modify it or change the target device, then a google for "PIC disassembler" should bring up plenty of hits for both free and paid-for software.
You can import the hex file into MPLAB (file>import) and then view it (view>program memory) but I don't know if you can edit it, at least from a quick look I had I couldn't see how you would make changes to the file so probably purpose written disassembler software is your best bet.
