Hex Buffer Decreases Voltage?
Discussion in 'General Electronics Chat' started by will3330, Feb 24, 2011.
  1. will3330
    Feb 24, 2011
    We are using a 4050 Hex buffer to amplify the current from a voltage signal of 5V to run a unipolar stepper motor. The problem is that when we send the signal through the buffer, the voltage on the output decreases to 2V which isn't enough to power the motor. We tried replacing buffer with another one but that did the same thing. Is there any reason as to why this is happening?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There may be a difference between the current the 4050 can handle and the current the motor needs for operation. Try looking at the data sheets. That 4050 is a buffer for going from CMOS to TTL more than a power booster.
  3. shortbus
    Sep 30, 2009
    4,095
    1,685
    A 4050 buffer is not for driving anything other than another logic device.
    Outputs can sink and source only about 1mA if you wish to maintain the correct output voltage to drive CMOS inputs. If there is no need to drive any inputs the maximum current is about 5mA with a 6V supply, or 10mA with a 9V supply (just enough to light an LED). To switch larger currents you can connect a transistor.
    From; http://www.kpsec.freeuk.com/components/cmos.htm
  4. will3330
    Feb 24, 2011
    K thanks. However, we are now amplifying the signal to a 74ls194 shift register and then buffer that to the motor. But, the problem is still there. :(
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Post your schematic.
  6. will3330
    Feb 24, 2011
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A logic device is good for maybe 6 to 24 mA. I'm guessing your motor needs more than that. The more current it tries to pull the lower the output high voltage. You are seriously stressing those parts. Post the specs for the motor as well.
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Use a SN754410 quad half bridge or ULN2803, the 4050 isn't powerful enough.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Wait a minute - your 4050 outputs appear to be going to an L298 H-bridge. Is that correct?
    Tell us more about the motor you're using - is it bipolar or unipolar? I see "unipolar" written over by the PIC16F877, but an L298 is a dual H-bridge - why use that when you'd be better off driving it in unipolar rather than bipolar?
    What current and voltage rating?
    And what voltage are you driving it with on the L298 connections?
    You won't be able to drive a motor using an L298 with a motor supply of 5v. The L298 will drop about 4v across itself even with just 1A current.
