Helping in building an IR light circuit
Discussion in 'The Projects Forum' started by marcolisi, Nov 19, 2008.
  1. marcolisi
    Nov 18, 2008
    15
    Hello guys,
    I need some help please.
    Im trying to build my own IR light source to add to my nightshot camcorder.
    I want buy a :
    1) 5 Watt Infrared IR LED Night vision camera Flashlight
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=250326011738
    but the guy that sell it , I think does not know anything about it.
    My guess is that to make the 5 watt IR led work (not to heat too much and blow up), I need two
    5 Watt LED Pulse Driver
    http://cgi.ebay.com/5-Watt-LED-Puls...205|66:2|65:12|39:1|240:1318#ebayphotohosting
    What I do not understand is :
    1) how do I connect two 5 Watt LED Pulse Driver to one 5 Watt Infrared IR LED Night vision ?
    My thinking is to connect :
    A) Power Source that has + and - to B) one 5 watt led pulse drive , connecting it to the + and - of the power source. Then connect to the 5 watt led pulse drive B) another C) 5 watt led pulse drive , connecting + with + and - with - . Then connect the D) 5 watt infrared IR led night vision to the C) 5 watt led pulse drive, connecting + with + and - with - .
    Am I correct ?
    2) Which is the power source that I should use in Voltage ? ( how many AA batteries I should use and should I use a resistor ?)
    For the question 2) , these are the specs of the :
    A) 5 Watt led puls drive :
    Frequency: 30KHz
    Type: Pulse Driver
    Operating voltage: 5V-8V
    Current(peak): 950mA
    LED support: Blue/White/Green/IR
    (note: it can drive a 3W IR LED in full power. You need two for a 5W IR LED)
    and of the
    B) 5 watt infrared led :
    Specifications
    Wavelength: 850nm
    Vf: 1.5V~1.6V
    If: 2500 mA+
    Dimension
    Backplate(W): 19.9mm
    Can u please help me ?
    Thank you
    Marco
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    I wouldn't buy a no-name-brand LED that has no datasheet and no instructions.
    It is not 5W, it is "up to" 5W. Do you want a continuous light or a flickering light?
    Do you want the LED to last longer than a few minutes?
  3. marcolisi
    Nov 18, 2008
    15
    I would like to have a continous light that would last a while.
    Do u have any advice in what could I buy ?
    I would prefer if it is something small and easy to carry.
    Marco
  4. HarveyH42
    Jul 22, 2007
    425
    5
    Never seen high power IR LEDs. Will have to look and see if this is for real. I always figured they kept the power output low, since there isn't a huge demand, and potential for injury and liability. I would think 5 watts if infrared at close range would cause some serious eye damage, quickly.
  5. marcolisi
    Nov 18, 2008
    15
    Thank you.
    Coming back to my initial question:
    how do I make the circuit of:
    5 watt led
    two led pulse drivers ( will the ir light blink ?)
    Power source ( which power source do I need to use?)
    You can see the questions in the previous reply.
    Thank you
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The instructions for the LED and pulser are a poor translation (?).
    So who knows???????
    No Name-brand.
    No datasheet.
    No info.
