Help
Discussion in 'The Projects Forum' started by tiggerlator, Jun 7, 2014.
  1. tiggerlator
    Jun 7, 2014
    16
    Sorry for the short thread title, but it seems my last attempt, had the bug.
    Here is a pic of the circuit diagram of the main amp board of a kenwood A58 amplifier. What i need is someone to point out were to connect to so i have a direct input to the power amp section, bypassing the pre amp. I have a nice rotel pre amp rsp 960ax, and i want to try and use the kenwood as a power amp.
    Here is my pre amp, and the denon ud-m31 i am using for power at the moment
    If it helps, here is the diagram for the seperate pre amp board that connects to CN6 at the top left of the diagram i poste in the op, i am sure this is were i need to connect to. From what i can figure out, the inputs go through their input section, then through the dolby section, then to here and then to the power amp section. I think i need to connect to 4-L 5+6-G 7-R from CN6 but need to be sure.
    basically, i cant afford a power amp to go with my rotel rsp-960AX so figured i would try and use the power amp section of the kenwwod, it is 60wx2, rather than using the denon.
    thanks for any help.
  2. wmodavis
    Oct 23, 2010
    737
    150
    Looks to me like 4th down on the connector on the left for one channel where the signal path is shown in bold with an arrow showing signal flow direction. The 7th one down goes to input of other channel. Be careful because the inputs do not look AC coupled so I'd put a capacitor in series to each input.
    tiggerlator likes this.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Agreed, pin 4 and pin 7.
    The first (larger) schematic shows the two wires from the "vol out" control, L and R going to pins 4 and 7 respectively.
    When hacking amps you can always connect to where the volume control was.
  4. tiggerlator
    Jun 7, 2014
    16
    Sorry if i should know, but how do i connect the capacitor, like this? Also, can i chop the connections from the amps input or just connect my input and leave the old amp input alone?
    What size cap will do?
    really thx guys
  5. tiggerlator
    Jun 7, 2014
    16
    Didn't work, i connected it with no caps, but the volume lvl was very low, could hardly hear it with the volume control turned right up.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Interesting.
    Can you unplug that preamp connector CN7/6 and try injecting the audio into the power amp input instead?
    On the large diagram the power inputs are on pins 2 and 10 of connector CN6.
  7. tiggerlator
    Jun 7, 2014
    16
    I will try that, in morning. thx
  8. tiggerlator
    Jun 7, 2014
    16
    Was gonna edit my post and add this, but can't seem to edit it.
    Here is the input board if it helps.
