Hello!!!!!
Friends How To Solve This Circuit By Mesh Current Method
That is not going to work.note : the upper left is i1 and upper right is i2 and the lower mesh current is i3.
1) 120 = 32i1 − 20i2 − 7i3
2) −80 = −20i1 + 25i2 − 1i3
3) What will be the third equation ??????????
I take the current direction clockwise and i write the two equation.That is not going to work.
Assume clockwise mesh current.
1) 5(i1)+20(i1-i2)+7(i1-i3)=120
Now let see you do it.
i3=-4 is it.I take the current direction clockwise and i write the two equation.
1) 5(i1)+20(i1-i2)+7(i1-i3)=120 is the same equation which i write but there is a problem in the third equation.
What will Be the Third Equation???
What does it HAVE to be in order to satisfy the current flowing in the bottom branch?I take the current direction clockwise and i write the two equation.
