HELP!
Discussion in 'General Electronics Chat' started by paulie, Jan 2, 2014.
  1. paulie
    Jan 2, 2014
    6
    I am not very familiar with electronics and am wondering if someone can assist me or at least point me in the right direction. I am wondering if a micro computer chip, say smaller than a dime can easily be affixed to an object and transmit an alert (beeping noise) to a receiver or piezo sensor/speaker when the two are separated by say 10 feet? If this is possible the more smaller and compact the better. Thank you.
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
    Yes. I would say it is doable but not without various technical challenges.
    paulie likes this.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Is this just to find your keys which you lost in the sofa?;)
    How rigid is the 10ft. separation? What kind of environment? Why wouldn't a 10ft. string work?
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I'd say it's definitely possible but you'd need to work very hard at it. You'd need to learn programming languages, how certain sensors work (how to run them and how to read from them), and various other things. It won't be easy, but it's definitely possible.
    paulie likes this.
  5. MrChips
    Oct 2, 2009
    12,625
    3,451
    paulie likes this.
  6. paulie
    Jan 2, 2014
    6
    Sorry this is all new to me. I'll get the kinks out.
  7. paulie
    Jan 2, 2014
    6
    Do you think this can be done with a magnetic strip rather than a computer chip. If so would it be less complicated, easier? Thank you for your help!!!!
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    what the balls?
    tshuck likes this.
  9. MrChips
    Oct 2, 2009
    12,625
    3,451
    Yeah, bare with me. I'll get this right one day.
    tshuck likes this.
  10. tshuck
    Oct 18, 2012
    3,531
    675
    You are still spreading your mod wings, you're good...;)
  11. tracecom
    Apr 16, 2010
    3,878
    1,396
    It's going to be 10°F tonight; I'll pass. :)
    DerStrom8 likes this.
  12. MrChips
    Oct 2, 2009
    12,625
    3,451
    Yes, I often get my bare, bear and beer mixed up, too often, especially after I've had too many of one of them.
    tracecom likes this.
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Perhaps the third is the reason for confusion between the first and second? :rolleyes::D
  14. Brownout
    Jan 10, 2012
    2,375
    998
    This is acheivable, but probably bigger than a dime. At a minimum, you'll need a processor, a sensor such as an accelometer to sense when the object is being moved, and a wireless communication module such as Bluetooth, which will send an alert to the reciever. Alternatively, you can just have the attached unit sound the alarm, and not use a seperate receiver. If you do this, you might not need a processor, rather a simple circuit that latches the accelerometer output and connect to an audio device. This would be the simplist way.
    A magnetic stip might be used in conjunction with a magnetic sensor, such as a hall effect device, to sense that the object was moved, and then similar electronics can sound the alarm.
  15. wayneh
    Sep 9, 2010
    12,379
    3,234
    What if: The base station sounds an alarm if an RFID tag leaves its range? That would allow the mobile part to be very small.
  16. huang
    Jan 8, 2014
    10
    generally speaking,we prefer the smaller size get compacted
