Background information: I'm designing a braking system for a mini wind turbine. My idea is to connect a low value resistor across the end terminals of the motor to increase current and torque. When not braking, there is a 10 ohm resistor connected across end terminals of the motor by default. I only need a basic idea for a circuit since this project is in early stages.
Is this something I should be aiming for or is that stupid?
Also this braking system should be activated once the wind speed reaches a certain speed, If I have a device that measures wind speed how would I create a circuit so that I get the 0.1 ohm resistor between the end terminals of motor instead of 10 ohm resistor automatically
All help is appreciated.
With thanks
Maru
With thanks
Maru
