HELP
Discussion in 'The Projects Forum' started by kince, Mar 19, 2013.
  1. kince
    Feb 26, 2013
    Hi I'm working on a energy harvesting circuit, and i want to harvest from Face Piezeo TH-7R using harvesting chip LTC3588.
    The problem is, my input voltage from the piezo is about 150Vp-p and the chip states it will only take in Vin max at 18V.
    I have connected some caps in parallel to step down the input to around 20p-p, but it seems to give me very minimal power at 3.3V, which cant even power a tiny LED.
    I suspect that it has got to do with the caps.
    Any suggestions to step it down by other means? Is resistor possible?
    datsheet: 7R http://216.71.30.251/Face%20International/7r-ds.pdf
    datasheet: LTC3588 http://www.linear.com/docs/28909
  2. shortbus
    Sep 30, 2009
    4,096
    1,689
    How are you using a piezo speaker to harvest energy? What is driving the speaker to give you a couple of times the rated voltage for the speaker. Some things need to be explained more. Post your schematic.
  3. MrChips
    Oct 2, 2009
    12,636
    3,454
    HELP - you can do better than that. Provide a proper title.
