help
Discussion in 'General Electronics Chat' started by aryam, May 17, 2010.
  1. aryam
    May 17, 2010
    hi , am working on a dc dc buck converter . the switch am using is a mosfet IRF740. and i have designed a gate driver with an optocoupler for the mosfet ,because my pwm source is 3v.
    but the gate driver circuit works fine /with a vcc =10/ and the dc dc converter circuit also works fine without being connected to the gate driver .but when i connect them the , it doesnot drive the mosfet .plz help me i cannot find any other fault .
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I moved your post to a more suitable place.
    Can you post the schematics of what you have upto now?
    Bertus
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The IRF740 is not a logic-level MOSFET. You must get Vgs to 10v before the MOSFET is fully turned on.
    I do not know why you are using a high-voltage MOSFET with such a low voltage. It is a poor choice for the job.
