Help
Discussion in 'The Projects Forum' started by micro, Jun 16, 2006.
  1. micro
    Feb 10, 2006
    26
    I just bought L297 and L298n IC. I have read through this two IC datasheet.
    But I still have some problem with L297 SYNC pin. Can anyone tell me
    how do I connect this pin? Thanks.
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    you could at least attach the 2 datasheets for easier analysis so we don;t have to go browsing for that. not all members have used that ic or has any knowledge on that so they can intelligently discuss it with you. ;)
    Does your sync pin connected to the clock pin of a binary counter?
    moz
  3. Dustooff
    Jun 23, 2004
    9
    the sync pin can either be used as a master output to other slave 297's, or as an input for said slaves. otherwise if you only have one 297 in operation then leave it floating/unconnected. figure 3 on the datasheet provides an example.
