1. ikram
    Mar 23, 2009
    i'm using mikroC for pic version 8.2.0.0. It is support for assembly language or not?thanksss
  2. KMoffett
    Dec 19, 2007
    2,584
    234
  3. AlexR
    Jan 16, 2008
    735
    54
    Most C compilers including mikroC allow you to embed either a single assembly instruction or even block assembly code within the C program by using the "asm" declaration.
    So the answer is yes microC does support assembly language but if you plan to write the whole program in assembler you would obviously be better off using a dedicated assembly language compiler like MPLAB.
