Help !!!!!
Discussion in 'Homework Help' started by WiLLiaMaybE, May 6, 2008.
  1. WiLLiaMaybE
    May 1, 2008
    Hey guys, its my very first post here...
    i need some help and pointers with coding and circuits..
    currently working on a project..
    but i had problems with my LED and codes...
    any1 can help with codes about sending SMS to operate LED lights??
    for schematics diagrams rite..
    how do u check for LCD driver type??
    cheers,
    MaybE
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Want help? Drop the textspeak! Write in English with correct grammar, spelling, punctuation, and so forth. It improves you chances of of a coherent reply by several orders of magnitude.
  3. WiLLiaMaybE
    May 1, 2008
    well...
    thx for the tips...
    i will try to write in perfect language..
    but for now...
    i reali need help with my codes..
    does any1 knows about assembly language...
    i wanted to turn my LED on/off by sending of SMS..
    any pointers??
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    "any pointers??"
    Stop using multiple puntuation like "??" and "..." It's meaningless.
    Capitalize "I" when refering to yourself.
    Stop using "any1", it is an annoying affectation.
    What devices will be used to send and receive the SMS messages?
    How will you connect the LEDs to those devices?
  5. Digi Dave
    Member
    Apr 25, 2008
    26
    Its not assembly language you need mate its "English" language!
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Clarity is important, especially in technical fields. We'll need more input as to what your after. How would your instructor expain the parameters?
  7. WiLLiaMaybE
    May 1, 2008
    I am writing a programme with micro-controller 16F877A connected with a GSM modem. Trying to operate LED on/off via sending of SMS to command it. but the problem here is that im using microcode studio to write it which only reads assembly language, which I am not familiar with.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    As I see it you have two choices; you can learn assembly language and continue to use your present tools, or you can assemble a new set of tools to use another language like BASIC, C, Sordfish, etc.
    I'm guessing that your interface to the GSM modem is through a serial port and that you have access to an AT-command set. Is this correct? Can you provide a link to a datasheet that describes this command set?
    Controlling the LED is nearly trivial as you no doubt already know.
