Hi
Please help me if you can
I need a three-circuit DC / DC Converter
1. The boost converter with the following specifications:
One of the following IC circuit: TL 494 or SG3525 OR SG3524 or MC34063 or UC3843 OR UC3842
VI=5
VO=15
FS(MOS)=30KHZ
IO=2A OR 3A
2. The bUCK converter with the following specifications:
VI=15
VO=5
FS(MOS)=30KHZ
IO=2A OR 3A
3. The (BUCK/boost) converter with the following specifications:
FS(MOS)=30KHZ
IO=2A OR 3A
The input voltage to the desired output
If the circuit is protected against overload and short circuit as well
And if possible adjustable
Thank you very much wait for your answer
VI=5
VO=15
FS(MOS)=30KHZ
IO=2A OR 3A
VI=15
VO=5
FS(MOS)=30KHZ
IO=2A OR 3A
FS(MOS)=30KHZ
IO=2A OR 3A
