help with voltage control circuit
Discussion in 'The Projects Forum' started by jboulasii, Aug 16, 2009.
  1. jboulasii
    Aug 16, 2009
    11
    I need to design a circuit that take 115VAC input and delivers about 100VDC output then after a set time period say 5 seconds the voltage drops to 55VDC.
    I was think that I could use a bridge rectifier circuit and that would get me my 100VDC but i'm sure on the best was to drop it down to 55VDC. I was thinking that I could open up the circuit on one of the diodes but i'm sure sure of the best was to do this.
    My other problem is that the packaging needs to be pretty small, about 2"x2"x1" give or take alittle.
    does anyone have any ideas?
  2. Søren
    Sep 2, 2006
    472
    28
    How much current is needed?
    What's it for?
  3. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Two options - SMPS or a stepdown transformer. Everything depends on your current requirement.
  4. jboulasii
    Aug 16, 2009
    11
    i need 10A
  5. rspuzio
    Jan 19, 2009
    77
    > i need 10A
    > 2"x2"x1"
    Since you need 10A at 55V, this sounds too small for the step-down
    approach -- a transformer rated for 500VA is going to be larger than
    that. To get that size you will need to do without a transformer, which
    means that your circuit will not be isolated from the power lines and,
    hence, only safe to use if all electrified parts are carefully hidden and
    insulated where a user could not bump into them. In particular, there
    will be no safe grounding point to which you could, say, connect any
    exposed metal parts.
    Another way of dropping from 115 to 100 to 55 is via a TRIAC
    arrangement as used in dimmers. By using an arrangement
    consisting of some fixed resistors and a transistor instead of
    a variable resistor, the circuit would output 55V or 110V depending
    on the logic level of a control wire. Then you could use an RC
    circuit to change the control wire after 5 seconds.
  6. jboulasii
    Aug 16, 2009
    11
    What I have now is a full bridge rectifier with an SCR replacing one of the diodes. If I just connect the gate to a positive voltage it trigger just fine. The problem I'm having is triggering it with an RC circuit. I've got a 10K resisitor and 25uf CAP. The timing may not be quite right but I can seem to get the SCR to trigger at all. Any suggestions.
