help with ups
Discussion in 'General Electronics Chat' started by obrcmc, Apr 30, 2009.
  1. obrcmc
    Apr 30, 2009
    can anyone tell me if i can change a ups of 600VA to a ips(inverter) which will serve to operate some fans or lights for 2hrs at least? i want to know if i can change the small 12V 7Ah batery to a big one can it serve me that way?
  2. abcinc
    Member
    Apr 29, 2009
    26
    Hi, depending on the ups you can extend the leads and connect them to any size battery of the same voltage as the usp battery. I have done this with a UPS with a 6V battery and hooked the leads to a group of 6V RV batteries. Then the 1000 VA UPS ran for 10 hours instead of 30 minutes. This is commonly done for phone systems. If using multiple batteries, install a fuse between the positive connections of the ups to first battery, fuse between first and second battery. The batteries are all in parallel.
    Dave
  3. obrcmc
    Apr 30, 2009
    thanks buddy, now i have to collect a battery :)
