Hi
I was doing some reading about this type of amplifier and I came across:
The analogue design tools can be used to determine how the circuit performs in real time. One method of doing this is to apply a defined stimulus to the circuit and examine how the output changes with time. As an example, you could apply a pulse input to the circuit and examine how quickly the output voltage responds.
Note that the output signal is inverted compared to the input.
I want to ask why is the output signal inverted?
Thank you
Thank you
