Help with understanding M68HC11 arrays
Discussion in 'Homework Help' started by bluesilver89, Mar 28, 2010.
  1. bluesilver89
    Mar 28, 2010
    Hello! I'm new here, but I was hoping to get some help understanding how to use arrays in the 68HC11 programming language. I have already completed a beginners Java course, so I understand the concept of an array. However, I do not understand how to manipulate them in an HC11 program.
    My homework assignment is to write an HC11 program that will initialize and manipulate an array, then write a series of 3 loop. The 1st copies an array of constants from EEPROM to RAM (which I attempted in the example below), the 2nd loop involves subtracting the first array element from the second, and then storing the result in the second (a[1] = a[1] - a[0]), and repeat for all the elements except for the assignments themselves (so no a[2] = a[2] - a[1], because a[1] is already being used as an assignment). It is assumed that the array contains an even number of elements. The 3rd loop sums the entire array into a single total and stores it into a variable. Each loop should be within the same program, but seperate from each other.
    I was able to somewhat figure out the first loop, but I am unsure how to manipulate the array from there. I learn best from seeing examples, so would it be possible for someone to show me a basic HC11 program that does something with an array (it doesn't have to be based on my homework, I just need to see an example on how to use arrays). Also, if anyone notices any problems with my posted program, can you point them out to me please? I would definately appreciate any help! Thank you for your time!
    Code ( (Unknown Language)):
    1.
    2. RAM       EQU       0
    3. EEPROM  EQU       $F800
    4. array      FCB       7, 24, 9, -12, 63, 87     * array of 6 constants
    5. asize      EQU       6                    * space reserved for array
    6. total      RMB       1                    * total variable for 3rd loop
    7.
    8.             ORG       RAM
    9. dst        RMB       asize               * space for destination array
    10.
    11.             ORG       EEPROM
    12. src        FCC       array
    13.             FCB       0                     * terminate array with null
    14.
    15. start       LDAB     #asize              * load asize in accumulator B
    16.             LDX       #src                 * load EEPROM in x register
    17.             LDY       #dst                * load RAM in y register
    18. loop       LDAA      0,x                  * load first element of array in x
    19.             STAA     0,y                  * store that element in destination
    20.             BEQ       loop2               * if null, loop to 2nd loop
    21.             INX                              * increment x
    22.             INY                              * increment y
    23.
    24.             DECB                            * decrement 1 from B
    25.             BNE       loop                 * if asize != 0, branch to loop
    26.
    27. * all this below is my incomplete attempt to manipulate the array for the 2nd and 3rd loops but I don't think I'm doing it correctly. I think I might have to use the 0,x, 1,x etc, but I'm not sure.
    28.
    29. loop2      LDAA     array[1]
    30.             LDAB     array[0]
    31.             SBA
    32.             STAA    array[1]
    33. loop3      LDAA    array[0]
    34.             LDAB     array[1]
    35.             ABA
    36.             STAA    total
    37.
    38. done
    39.
    40. JMP      END      JMP
    41.
    42.
    43.
  2. RiJoRI
    Aug 15, 2007
    536
    26
    Consider using pointers in loop2 as you did in loop1. Or even one pointer:
    1.
    2.   ldaa   ,x
    3.   inx
    4.   adda  ,x
    5.   staa   ,x
    6.   inx
    7.
    Please note that I am familiar with the 6809, not the 6811. There may be features the '09 had that the '11 doesn't, and vice-versa.
    Another method:
    1.
    2.   ldx  #00
    3. loop:
    4.   ldaa  array,x
    5.   inx
    6.   adda  array,x
    7.   staa   array,x
    8.   inx
    9.   cpx    DST
    10.   bne    loop
    11.
    Question: Did the teacher mention what to do when you have an overflow/underflow? E.g., $80 + $82 = $02 (with the Carry bit set). If not, don't worry about it. You'll get to it pretty soon.
    --Rich
