Help with two port network question
Discussion in 'Homework Help' started by csw123, Feb 27, 2014.
  1. csw123
    Feb 27, 2014
    16
    hi everyone, the question is to find the Hybrid parameters (h-parameters) of this circuit, i tried and i have no idea how to do that.
    thx :)
    the circuit attach as image.
  2. WBahn
    Mar 31, 2012
    18,096
    4,920
    So since you tried, you should be able to post your best attempt (doesn't matter that it was unsuccessful) to solve the problem. That will give us a starting point to work from.
  3. csw123
    Feb 27, 2014
    16
    well its not really something that can help, the way to solve this its from those equations (image), and someone also told me to try and convert this circule into a Parallel circuit (but i have no idea how to do that).
    thx for the quick respone :)
  4. LvW
    Jun 13, 2013
    674
    100
    csw123,
    at first, you should know how the hybrid parameters are defined. Do you?
  5. csw123
    Feb 27, 2014
    16
    yes i do, but its still kinda diffrent then the normal hybrid circuit
  6. studiot
    Nov 9, 2007
    5,005
    515
    Why is is different?
    The whole point of a two port network is that is doesn't matter what is in the box. Everything is defined in terms of the voltage and current that appear at the two pairs of terminals.
    LvW is quite right, Do you understand what the conditions mean that you have posted in your post#3?
  7. csw123
    Feb 27, 2014
    16
    well i understand the general idea and ive done that with z-parameters.
    i know that i need to make a voltage and current equations and work from there but i just dont manage to do it on this circule.
    if you think i dont fully understand the idea i will be happy to learn :)
    thx again
  8. studiot
    Nov 9, 2007
    5,005
    515
    What I am asking is:
    You have noted that V2=0 and I1=0 as conditions.
    what does this mean for the conditions at the two port terminals.
    You must have covered this in Z parameters as well.
  9. LvW
    Jun 13, 2013
    674
    100
    That means: How do you realize these conditiones?
  10. csw123
    Feb 27, 2014
    16
    ha ok, now i understand your question, i got the "normal" hybrid circuit (image) and from that i got 2 equations : v1=h11*i1+h12*v2 and i2=h21*i1+h22*v2.
    to find h11 i need i1=0 and etc. but i dont know how to do with the question circle
  11. studiot
    Nov 9, 2007
    5,005
    515
    If I1 = 0 is the input open circuit or shorted?
    How about the output?
    If V2 = 0 is the output open circuit or shorted?
    How about the input?
  12. csw123
    Feb 27, 2014
    16
    I1=0, both are shorted.
    V2=0, both are open.
    thats for the normal h circuit, the question circuit just look diffrent, i always get the equations for the circuit givning at the question and get those terms from there, its just hard to figure out what to do in here.
    can you give me a lead of how to solve this?
    and again thank you :)
  13. csw123
    Feb 27, 2014
    16
    and i have another question
    the image i just uploaded
    the circuit is the upper one, he divided this into 2 ports
    the upper one and the T one.
    my question is about the first one (the square)
    i want to know if this matrix it is the correct answer
    thank you
  14. studiot
    Nov 9, 2007
    5,005
    515
    I think you should re-read about h parameters in your textbook.
    I have attached a very quick sketch of the basics, including how they apply to a bipolar transistor, where they are normally used.
    Given the four quantities that appear at the external pairs of terminals (input voltage and current, output voltage and current), six sets of equations can be derived connecting these.
    Impedance, Admittance, Hybrid, Inverse Hybrid, Transfer, Inverse transfer.
    They all work in the same way being a pair of simultaneous equations connecting one of the quantities with two of the others via parameters.
    Note that the parameters do not necessarily have the same units in any set
    So
    h11 is an impedance (resistance)
    h12 a pure number (scaling factor)
    h21 is a pure number
    h22 is an admittance (conductance)
    Each equation in the pair defines one variable in terms of the sum of two others times an appropriate h parameter.
    If we can choose external conditions such as a short circuit or open circuit we can eliminate one of these variables from the equations, so enabling the second to be defined in terms of the input or output voltage (current) alone.
    We do not simultaneously short or open both input and output.
    So in my first equation if we short the output v2 becomes zero, but I2 does not vanish because h22 still exists.
    However we can now find a relationship between V1 and I1 and solve for h11.
    and so on for the others.
    Now can you apply this to your circuit (with transformations if required) ?
    csw123 likes this.
  15. csw123
    Feb 27, 2014
    16
    ok first thank you so much!
    and secend i understand that i need to find V1 and I2 equations
    so my equations is : v1=(R1*alpha) I1-(R1/R2(R+1))V2
    I2=(alpha-1) I1 + beta/(R2(beta+1)) V2
    thats correct?
    *the main question was to find whats alpha equal so the matrix will be reverse, so i need to Determinant that so it will be equal to 1, so i know my Determinant cant contain beta and i still got beta in there so something have to be wrong with my equations, can u point for me whats the problem?
    thx
  16. csw123
    Feb 27, 2014
    16
    *actually im not sure if they said anything about R1 and R2 (it was a question from test)
    so ignore the previous *
    but i just want to know if my equations are true
    thx
  17. csw123
    Feb 27, 2014
    16
    I uploaded my answer, can u take a look and tell me if thats correct?
    thank you :)
  18. studiot
    Nov 9, 2007
    5,005
    515
    Your Z matrix is your post#13 is a little short on algebra.
    Since this is a passive network and easier than one with sources I have worked through some algebra and left you some to finish off.
    You must use your knowledge of basic circuits (ohms law, series, parallel resistors, voltage dividers etc) to deduce the expressions for the z parameters in the matrix.
    At least they are all impedances (resistances in this case)
    csw123 likes this.
  19. csw123
    Feb 27, 2014
    16
    the Z matrix i asked about its not mine its something i had in my friend textbook and i thought its wrong matrix, i guess i was right ;)
    thank you so much
    and my H matrix at post#17 for the orginaly question its correct?
  20. studiot
    Nov 9, 2007
    5,005
    515
    But can you follow the derivation of the simple z matrix?
    And can you calculate the final z parameter I left for you?
