Hi there,
My AFG 3.1AT treadmill display & control console suddenly died, it receives power but there is no light or sound when I turn the treadmill on.
I don't want to spend $300-400 on a replacement board, and I don't want to try to fix it.
What I want to do is to control the running belt with a simple device. (probably a simple PWM circuit, a PIC or even a full blown Rpi project)
But first I need to know how to control this thing.
I couldn't find a schematic of the board (Johnson MLH091PC), and don't know how to reverse engineer it.
The 8 pins socket (JP2) is connected to the upper board, and has nothing written on it.
On the upper board the pins are identified as
So I'm guessing:
Any advice, existing schematics for this board greatly appreciated.
-Fred
Programming background, very basic electronic, can solder, I own a DMM and a dead treadmill
- POWER,POWER,DA,SAFE,SAFE,DB,GND,GND
So I'm guessing:
- DA or DB must be used to PWM the main motor
- (then I wonder what is controlling the elevation motor)
- SAFE pins for connecting the safety switch
-Fred
