help with transistor switching
minkey01
Joined Jul 23, 2014
185
Hi. Could someone review this circuit and let me know if it will work as I intend? Questions below :
1) The trigger will sometimes be connected to different sources ranging from -15V DC to +15V DC. Is this ok? Can the circuit handle this range and will it still trigger throughout that entire range (everything except 0V)?
2) Is that 30V too much? How much can I put through that transistor?
3) Do I have the wiring right? I want the output of 30V to be turned off and on by the trigger.
4) Are my component values right?
Let me know what you think. Thanks so much for the help!
jjw
Joined Dec 24, 2013
823
1) Output is ~ 0V when trigger is from about +1.8V to +15V. Otherwise +30V
2) 40V is absolute maximum
3) Wiring is ok
4) Values are ok, R9 might need adjustment depending on the circuit connected to it.
34,280
To elaborate slightly on jjw's post --
1)For that circuit the transistor will be fully on when the trigger voltage is above about 2V and fully off when the trigger voltage is 0V or less.
It will stay off when the voltage is negative.
If you want the transistor to be on for either a positive or negative input, then you will need to modify the circuit. I have a circuit using a couple added transistors that will work, if that's what you need.
2) 30V is fine for that transistor. It's rated for 40V maximum.
3,4) The circuit and component values look okay, with the limitations in operation I noted in 1).
minkey01
Joined Jul 23, 2014
185
thanks guys.
but JJW is saying the ouput is +30V when then transistor is off and +0V when it is on.
Crutschow is saying the opposite.
hmmmm...if the trigger is 0V, I would think the transistor is off and that output at R9 would be 0V. JJW, are you sure?
Ok. I don't mind the negative trigger volts not doing anything. We can leave it, as long as it won't damage anything?
What is the max trigger +V for this transistor?
What are the different reasons R9 should be adjusted?
Thanks for the help on the details!!
jjw
Joined Dec 24, 2013
823
thanks guys.
No, Crutschow says the same thing: when voltage is above 2V, the transistor is fully conducting and it pulls the output to about 0.2V
When transistor is off, no current flows through R9 and the output is 30V.
If the output is connected for example to a 10kohm resistor the output swing would be 0-15V.
If about 30V swing is needed, R9 should be much smaller and also the base current of the transistor should be increased.
minkey01
Joined Jul 23, 2014
185
If no current is flowing through R9, how can the output be 30V?
Ohms law say V=IR. V= 0 x 10,000 = 0
AnalogKid
Joined Aug 1, 2013
10,986
Correct, but that 0 V is the voltage *across R9 only*, not the voltage from either end of R9 to anywhere else.
30 V (top of R9) - 0 V (voltage drop across R9) = 30 V (bottom of R9). Something to remember, Ohm's Law is a very local calculation. It relates the voltage across a part to the current through that part only. Extending this to voltages and currents somewhere else depends on the circuit, device physics, and many other details. So the output with the transistor off is 30 V with respect to GND, and 0 V with respect to the other end of the load.
ak
jjw
Joined Dec 24, 2013
823
yes. i think i want across R9. i'm trying to turn 30V off and on. this is the correct way to do it?
thanks.
What do you want to do?
Switch 30V supply voltage to some device or have some trigger signal 0-30V, which you now have between R9 and gnd ?
minkey01
Joined Jul 23, 2014
185
why is this getting so confusing? lol
this is a simple transistor switch circuit.
this is what i want:
when the SYNTH GATE INPUT is 0V then the transistor should not be activated and therefore 0V across R9 (marked OUTPUT)
when the SYNTH GATE INPUT is 15V then the transistor should be activated and therefore 30V across R9 (marked OUTPUT)
minkey01
Joined Jul 23, 2014
185
ak
i am only worried about the area marked output (across R9), because i'm using this as the output.
if my output was wired differently, yes there would be different results, but that is not the circuit.
jjw
Joined Dec 24, 2013
823
Yes, the circuit works as you want, there is 0V or 30V across R9 or in other words 30V or 0V between R9 and gnd.
MikeML
5,444
If the output is not loaded at all, here is a sweep of the output vs the input voltage. Note the "trip point" around 1.5V.
The bigger question is what happens when you load the output. Here is V(out) for values of load resistance = 100, 1K, 10K, 100K and 1megΩ:
cmartinez
Joined Jan 17, 2007
8,218
Mike, could you post the .asc file for the second circuit? I'd like to see how you created a variable load at the output. Thanks!
AnalogKid
Joined Aug 1, 2013
10,986
The circuit I described and responded to is the one in your schematic. What I wrote describes the output of that circuit. If you don't see that, then I'll try again.
ak
ScottWang
Joined Aug 23, 2012
7,397
Ic=(30V-(Vce_Q1)_/R9
Ic=(30V-0.2V)/10K
Ic=2.98mA
According to the datasheet the Vce get into the saturation status then hFE = 10, Ib=Ic/10=2.98mA=0.298mA, the Ib is not enough 1mA, so maybe the bjt won't get into the saturation status.
Assuming that the Ic =50mA, Ib=50mA/10=5mA, Vbe=0.95V, V_R13=5mA * R13 = 5mA*10K = 50V
I_R10=0.95V/R10=0.95V/10K=95uA, so ignore it.
Vin max = 50V+0.95V=50.9V.
AnalogKid
Joined Aug 1, 2013
10,986
That is exactly what your circuit does, up to the max collector current for the transistor.
Why is this so confusing?
ak
