Hello guys
For the past few weeks I've been working on a little ambilight-like project (in vein of http://divxstation.com/article.asp?aId=151, but with a different microcontroller setup, and some other minor changes), and so far, everything software-wise have been going pretty smoothly.
My only real problem lies with the transistores turning on and off the RGB-leds, which I can't seem to get working -I've tried calculating the needed resistor sizes through some measurements, but it still didn't give enough amperes for the LEDs.
I'm working with two kinds of RGB LEDs (http://www.dotlight.de/shop/product_info.php/cPath/263_264/products_id/744 and http://www.dotlight.de/shop/product_info.php/cPath/263_264/products_id/340), one having one anode and three cathodes, and the other having one cathode and three anodes, and therefore two different transistors - BC557NPN and BC547PNP.
If I could get some help getting just one of the posted schematics working I would be very grateful - it's the sizes of R2 to R7 I need help with.
Datasheets can be found at:
http://www.dotlight.de/datasheets/LL-U48RGB3C-001.pdf
http://www.dotlight.de/datasheets/SRGB7130.pdf
http://www.datasheetcatalog.org/datasheet/mcc/BC556B.pdf
http://www.datasheetcatalog.org/datasheet/mcc/548B.pdf
Edit: I only have those two transistors available, so recommending another transistor will not be helpful, unless there's no chance of getting them to work.
