Help with transformer for stereo tube preamp
Discussion in 'General Electronics Chat' started by FSTOP, Jan 30, 2009.
  1. FSTOP
    Jan 26, 2009
    6
    Can someone help me find the correct power transformer for a stereo tube pre-amp kit? The specs say: AC 180V-0-180V 2*AC 6V 30W
    Attaching a photo of schematic as well.
    Any information or advice will be appreciated. I don't know anything about power transformers, so i'd appreciate any advice everyone can give me!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. FSTOP
    Jan 26, 2009
    6
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, the transformer you found should work fine.
    For the other 6.3v transformer, practically any 120v to 6.3v transformer will work, but get one with a fairly low current output - you won't need much.
    Mouser or Digikey should have what you need in stock.
  5. FSTOP
    Jan 26, 2009
    6
  6. Andrew Leigh
    Sep 8, 2008
    92
    Hoffmanamps.com
    Specialise in tube stuff
    Andrew
  7. FSTOP
    Jan 26, 2009
    6
  8. mikeska
    Feb 18, 2009
    7
    The easiest way to get Vacuum tube stuff is to buy broken equipment from ebay and pawn shops. Very likely, most of the electrolytic capacitors are going to be dead, but you can acquire lots of useful high power parts, sockets, transformers, etc... Worth giving a shot if you can't find something in the right price range.
    Another alternative which you can try, is to build a little switching power supply to jack up the voltage to a couple hundred (I've used this to power a bunch of "Nixie" tubes for a photo darkroom timer ).
    If you need an output transformer for a power amp. though, you;ll need to go the pawn shop/ebay way, since most new trafs are too expensive imho.
    And the 6v transformer you can probably get from Radio Shack, for the heater.
    You can find exactly the specs the Vacuum tubes will require on their datasheets.
    ~mikeska
