help with trades.exambank.com questions
Discussion in 'Homework Help' started by peeka, Apr 25, 2009.
  1. peeka
    Apr 25, 2009
    21
    a 120 volt 60 hz circuit consists of coil that draws 4.8 amps and dissipates 205 watts,
    if a 230 microfarads capacitor is connected in series with the coil the new ciruict current would b ?
    the answer says 8.1 but i keep getin 4.3 or 4.8.
    btw this is no homework, this is study and im trying to clarify from wat i did bout 2 years ago since ive completed my apprenciship in australia and now converting it over here in canada so its really hard no one to help me so yea. hopefully someone answers me soon coz this is really pissing me off.
    thanx in advance
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    Did you account for the inductance of the original coil? (Yes, you are given enough information to figure that out! Hint: dissipation only accounts for the RESISTIVE part of the original impedance.)
    Let me know if that helps.
    Eric
  3. peeka
    Apr 25, 2009
    21
    i havnt tried that question :p but i need some clarifycation with this formula that canada has, active current = total current * power factor.
    now the thing i cant wrap my head around is i use the triangle to do everything neally.pythagoras one, anyways ive neva seen this formula and im jsut wondering wat else is called the active current ? coz the total current is the total line current which is obvous and the pf is powerfactor :p simple, but the active current is that the phase current ? for me would b Ip. and total current would b IL.
    thanx for the really early reply :p wasnt expecting it but i will try that question again the dissapation (watts) or power, ive taken into account sorta :p
    ill tell u wat ive done it mite help u lol.
    r= v/i , v = voltage. that , 120/4.8 = 25
    then the capacitor xc = 106/ 2pie x 60 x 230 = 11.53
    i found impedence of that use the triangle Z = 27.53.
    then I = v/z which is 120 / 27.53 = 4.35 n thats the answer i get. and ideas lol :p
    most of the math questions i cant wrap my head around it but theory is easy :p dont ask me why lol.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The solution can go as follows:-
    1. Find the coil resistance,
    Rcoil= Power/(I^2) = 205/(4.8^2) = 8.9 Ω
    2. Find the coil reactance,
    Xcoil = Vx/I
    Xcoil = (√(120^2 - Vr^2))/4.8
    where Vr = volt drop across coil resistance and
    Vr = Rcoil * I = 8.9x4.8 = 42.71 V
    Hence Xcoil = (√(120^2-42.71^2))/4.8 = 23.36 Ω
    3. With 230uF capacitance in series - capacitive reactance
    Xc = 1/(2*Pi*60*C)
    Xc = 11.53 Ω
    4.Total reactance,
    Xt = Xcoil - Xc
    Xt = 23.36-11.53
    Xt = 11.83 Ω
    5.Total series impedance,
    Zt = √(Rcoil^2+Xt^2)
    Zt = √(8.9^2 + 11.83^2)
    Zt = 14.8 Ω
    6. New current = 120/Zt = 120/14.8 = 8.11 Amp
  5. peeka
    Apr 25, 2009
    21
    jeez dont i feel like an idiot :p
    oh well live n learn i spose :) thank you t_n_k appreciate the help and that lovely explanation very easy to follow ill let u know how i go :) thanks
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    No need to fool feelish at all! This was actually a rather tricky problem (though a very good one!)
    There are two things to watch out for....problems that give you more information than you need....these can lead you down the garden path.....and those that don't SEEM to give you enough information (as in this case).
    Another approach you can use here is to first figure out the Real and Apparent power, and the phase angle. Then you can work backwards and see if you get the same answer! Quite a few more algebraic gymnastics involved, but it does lead to some great insights.
    Eric
  7. peeka
    Apr 25, 2009
    21
    okay i understand real and apparent power :) and phase angle coz thats easy for me to understand. but that xcoil is funky neva seen that b4 but oh well like i said ill go thru the examples u guys gave me and the hints and ill work it out :) it looks like t_n_k used the reactive capacitance formula which i know :p but that xcoil is weird neva seen that.
    well ill let u know how i go with this one ill try probs today at work thank u so much for the help :)
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    I was a little cryptic in my derivation of Xcoil. It's never easy knowing how much info to write in a "succinct" response.
    Perhaps some further explanation might help.
    The coil may be viewed as a series combination of its resistance and inductive reactance - the latter I called Xcoil.
    So Vcoil = √(Vr^2+Vx^2) where Vr is the resistive voltage drop and Vx is the reactive voltage drop. Of course these two voltages are out of phase & hence the pythagorean summation. I haven't concerned myself with phase angles - just resultant magnitudes.
    BTW - I had in mind your earlier statement that you used Pythagoras for your calculations so I had tried to stick with that approach.
    So rearranging the previous equation I get
    Vx = √(Vcoil^2-Vr^2) - Vcoil and Vr are both known
    and since we were given the current I we can find the coil reactance using
    Xcoil = Vx/I
    Hope that clarifies the mystery of Xcoil....
    Knowing Xcoil and Xc (capacitive reactance) I was then able to calculate the new series reactance (i.e. the difference between the two) when the capacitor was added to the mix. From there I went on to calculate the new total series impedance (magnitude only) which includes the original resistance term.
    And so on ...
  9. peeka
    Apr 25, 2009
    21
    where u said
    "since we were given the current I we can find the coil reactance using"
    Xcoil = Vx/I
    thats just the resistance of the coil ? am i right ?
    and where u say Vx is the reactive voltage drop ? is that the capacitors voltage drop wit the resistance of 11.53 ? arghhh damit cant understand anything anymore :(
    thers a part , part 4. total reactance
    xt = xcoil - xc (now where and how did u get that formula or knowledge to do that ?)
    as u know im not the smartest :p but im very stuborn to get something perfect :p which i spose is very good. well many thanks to ur replys they are helping me alot :) im taking off friday to study all day coz im hoping to sit the exam in june.so if u got msn would b nice to talk to u bout that stuff always fun. djpeeka@hotmail.com
    cya
  10. peeka
    Apr 25, 2009
    21
    im also a lil hazy on the "coil reactance"
    like wehre did u find that formula ?
    xcoil = (root(120^2 - Vr^2))/4.8
    or did u make this formula up from ohms law v=ir and something ?
    is there another way around this question using the triangle pythagoras method ?
    where Z is hypotenuse
    R is adjacent
    Xl or Xc is opposite
  11. peeka
    Apr 25, 2009
    21
    another question how do u add phasor angles god im sooo fkn pissd cant even do that :(
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    To read about the difference between resistance and reactance may I suggest you read some of the sections in VOL.II - Ac on this site. This is general link above but the following link discusses series LR circuits.
    http://www.allaboutcircuits.com/vol_2/chpt_3/3.html
    When you "add" inductors & capacitors in series to obtain an equivalent reactance, then you keep in mind that their individual reactance terms need to be added with regard to their sign. This has to do with the complex algebra that is used to analyze AC circuits. For the simple series case in your problem consider the inductive reactance as being positive sign and the capacitive reactance as being negative sign. To fully appreciate this you need to review complex numbers - if indeed you have used them in the past. If not then you'll need to get a handle on there use in AC circuit analysis.
    While it's possible to analyze everything just using pythagoras triangles, more complex problems need more powerful techniques to solve them efficiently.
    I understand your frustration - unfortunately it's usually a matter of time and hard work required for this stuff to sink in. If you are doing this "solo" it's much harder still - are there any refresher classes or courses you might be able to attend? Anyway - read through the notes on this site as suggested.
  13. peeka
    Apr 25, 2009
    21
    and yes im working on this solo :( but im going to call this tutor today who lives around my area. so hopefully he can help me :p
  14. peeka
    Apr 25, 2009
    21
    okay ive found a close answer to it,
    i got 8.24 amps.
    now the way i did it was from that example u passed me.i found the resistance of the full resistor R = p/i2
    8.89
    and found Xc which is 11.53,
    so root(11.53^2 + 8.89^2 )
    gives me 14.55 ohms
    so then thats the full resistance of it, or reactance wateva u wana call it :p
    so then I = V/Z which is 120/14.55 gives me 8.24 amps.
    now is this correct coz i dont see how and why u would want to find the coil reactance of the resister.coz 1. i didnt see that in the example. and 2 neva seen that b4 :p so please let me know okay :) im dieing to know
  15. KL7AJ
    Nov 4, 2008
    2,047
    295
    col reactance (XlL)= 2 pi F L
    Eric
  16. peeka
    Apr 25, 2009
    21
    im having trouble once again :p with this question.
    a 240 volt 60 hz , has a heater and a singlephase motor connect in parallel.motor uses 1300 watts power at pf .4 and a heater dissapates 600 watts.wats the total line currents (its spose to b 14.72A)
    now i know i gota do something similar to the other question.i just cant rack my brain around it at this point hence why im asking :p and yes ive called the tutor guy up got answering message :( hopefulyl im not anoying u guys :p.
    most of my answers for this question i get around 13.7 or 21a so i know imdoing something rong :p
  17. t_n_k
    Mar 6, 2009
    5,448
    783
    The power factor tells you that not all of the current is going towards producing real power losses (= output torque) in the motor.
    Remember that Real Power = apparent power * pf
    So for the motor first ...
    Real power = 1300W
    Apparent power = 1300/0.4 = 3250 VA
    Using pythagoras
    Apparent power = √((real power)^2+(reactive power)^2)
    Reactive power = √((apparent power)^2-(real power)^2)
    Reactive power = √(3250^2 - 1300^2) = 2979 VA
    For the heater it's OK to assume the pf = 1 (since you were not told otherwise)
    Real power = 600 W
    Apparent power = 0
    For the combined system
    Total Real Power = 1300 + 600 W = 1900W
    Total Reactive Power = 2979 + 0 = 2979 VA
    Total Apparent Power = √(1900^2+2979^2) = 3533 VA
    The Line current = Total Apparent Power / Vsupply = 3533 / 240 = 14.72A
  18. t_n_k
    Mar 6, 2009
    5,448
    783
    That should read ..
    Real Power = 600 W
    Apparent Power = 600 VA
    Reactive Power = 0
  19. peeka
    Apr 25, 2009
    21
    god that was an easy question lol once u know how and wat to do with it ,it really becomes easy.maybe im just stressing to much and therefor i get jumbled up in everything.
    well thanx again for explaining t_n_k :) appreciate it.
  20. t_n_k
    Mar 6, 2009
    5,448
    783
    No problem peeka.
    Get out and enjoy some fresh air away from the books - it's the weekend!
