Help with this solving this equation !!!!!
Discussion in 'Math' started by kingmort, Mar 20, 2011.
  1. kingmort
    Mar 4, 2011
    Please help me to prove that
    X" + ( a^2 )X = 0 where X= Asin(ax) + Bcos(ax)
    Cause I got a different expression with an exponential and when I use maclaurin to approximate my expression and the supposed function , I found them to be different .
    Help would be greatly appreciated !!!!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    This might help
    X=Asin(ax)+Bcos(ax)
    X'=aAcos(ax)-aBsin(ax)
    X"=-a^2Asin(ax)-a^2Bcos(ax)
    a^2X=a^2Asin(ax)+a^2Bcos(ax)
    X"+a^2X=?
    SaraSa likes this.
  3. kingmort
    Mar 4, 2011
    hi , thanks for the reply , however would you mind trying to solve the differential equation above ? i m trying to see if i did the solved it wrongly ... thanks !!!
  4. kingmort
    Mar 4, 2011
    i mean solved it wrongly
  5. kingmort
    Mar 4, 2011
    Solved it already ... Need not bother about this thread
