Its output voltge is +4.5V which rises to +8V which is too high to feed into a PIC. The +8V might damage the input of the PIC. You should attenuate it with 2 resistors.audioguru
i have made the circuit and connected it to PIC and i had the correct output!
Simply connect a 330nF coupling capacitor feeding a 100k volume control to the output. The volume control feeds an LM386 little power amp IC circuit that drives the headphones.i'm thinking to have an extra feature on my project by adding a headset to listen to the heart sounds!
the one i constructed feeds the signal values into PIC but here i want to add a headset circuit so that i can listen to and watch the signals.
can i do that without affecting the current constructed circuit's values?
if yes, how can i do it?
