yes it's theoretically possible, but i can't do it practicallyIn the diagram you posted I see a high DC voltage.
Are you allowed to produce it by using a rectifier in your project?
If yes, then you won't need a transformer.
Why?yes it's theoretically possible, but i can't do it practically
If this is the case then you must use a 12V or maybe higher voltage battery (i think they will equip cars with 48V batteries to save copper used for wires) with a transformer.I'm in Power and Machines department in my college, so my project must be related to it.
my main project is Multi-Level Inverter and it's used for traction loads and HV linking between different frequency electric girds between countries.
So, this simple circuit (which for me is a huge problem) is the 1st step to do it.
I'm not only allowed to do it, I'm forced.
yes you're right and these batteries provide very high current rating.If this is the case then you must use a 12V or maybe higher voltage battery (i think they will equip cars with 48V batteries to save copper used for wires) with a transformer.
The datasheet explains it. Didn't you look at it?I didn't knew that the MOS needs 10v to fully turn on
Good point Audioguru. That is one reason to use a proper driver for MOSFETs which will drive then fully on.The datasheet explains it. Didn't you look at it?
Some people see the "typical gate threshold voltage" but some Mosfets are good and some are not so good. The guaranteed minimum current at the threshold voltage is only 0.25mA.
Thank you Guys for everything, I think I'll use a MOS driver, and I'll try to implement it in real and tell you updates.Good point Audioguru. That is one reason to use a proper driver for MOSFETs which will drive then fully on.
by Aaron Carman
by Aaron Carman
