Hello again,My instructor said use thevenin theorem to get the RL voltage , and he said it would be simplier to get the other voltage after you get the voltage at RL ,,, and i dont know what method i use after i get the ,RL voltage is 3.24324V .. RTH=60/11 ,,, ETH=5.454545 V
i need to findd the resistor voltage across the circuits help
Since he said "it would be simpler to get the other voltage(s) after you get the voltage at RL" then it sounds like he just wants you to use your imagination to try to find another way to find the other voltages. You can do that by simply working backwards noting the current through the previous section. Note that to start, you already know the voltage at the output so that means you know the current through the output, and since that same current flows through that 4 ohm resistor also (it's in series) that means you know the voltage across that 4 ohm resistor.
Referring to the image in the attachement with all the parts labeled...
Once you have the voltage at v6 and the current through RL, that means you know the current through R5, and once you know that, you know the voltage at v4. Now that you know the voltage at v4, you can calculate the current through R4, and knowing the current through R4 and R5 you can calculate the voltage at v2 because you know the voltage across R3 due to the current through R3 being the sum of the other two currents. That gives you all the voltages except v1, and you can calculate that by simply adding up the voltages of all three voltage sources.
So you see once you have the output voltage it gets easier so you dont really have to use Thev/Norton for each and every single resistor. You do have to know that the sum of the currents entering a node is equal to zero though, and then work backwards trying to find any current necessary in order to reveal the voltage across the next resistor to the left, and then that gives you the next voltage to the left, and then repeat the process again working right to left.
