help with these circuit pls...
Discussion in 'The Projects Forum' started by tsukaranz, Sep 28, 2011.
  1. tsukaranz
    Aug 23, 2011
    24
    please help me to specify the parts needed in this circuit...
    i badly need this one for my project...
    i couldn't found anywhere on the internet...
    http://www.youtube.com/watch?v=F36IislTWbY
    thanks in advance...
  2. tsukaranz
    Aug 23, 2011
    24
    any updates??
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    No need for bumping.
    This is an international forum, so answers can take upto 24 hours.
    Bertus
    tsukaranz likes this.
  4. tsukaranz
    Aug 23, 2011
    24
    i really need this thing...
  5. elec_mech
    Nov 12, 2008
    1,513
    193
    Qty Description
    1x NE555 Timer IC
    4x 1kΩ Resistor, 1/4W, 5%
    1x 1MΩ Potentiometer, 10-turn ideal for finer control, but 1-turn acceptable
    1x 10uF Electrolytic Capacitor, +/-20%, 16VDC or higher
    2x 1N4001 Rectifier Diodes
    2x NPN Transistors, part number depends on motor current
    2x 5VDC Coil, SPDT Relays, part number depends on motor current
    1x 5VDC supply capable of powering motor
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I went on Falstad and threw together a simulation for you to experiment with:
    http://www.falstad.com/circuit/#$+1...+144+240+144+0 o+5+64+0+35+1.25+0.00625+0+-1
    The values I used aren't the same as what elec_mech supplied; as this is just a simulation so that you can see something work and experiment with the values.
    Just in case the schematic gets lost, here's the export/import file:
    Code ( (Unknown Language)):
    1. $ 1 5.0E-6 10.20027730826997 50 5.0 43
    2. 165 176 176 192 176 2 5.0
    3. c 128 352 128 400 0 3.2999999999999996E-5 0.6543065998874835
    4. w 176 272 160 272 0
    5. w 160 272 160 304 0
    6. w 176 304 160 304 0
    7. w 160 304 128 304 0
    8. w 128 304 128 352 0
    9. 174 128 240 128 304 0 4670.0 0.5 Resistance
    10. w 128 208 176 208 0
    11. w 128 144 240 144 0
    12. 178 416 48 480 48 0 1 0.2 0.1812730369914894 0.05 1000000.0 0.02 20.0
    13. 178 416 160 480 160 0 1 0.2 0.1812730369914894 0.05 1000000.0 0.02 20.0
    14. g 128 400 128 416 0
    15. g 416 160 416 176 0
    16. R 240 144 240 112 0 0 40.0 5.0 0.0 0.0 0.5
    17. R 416 48 416 16 0 0 40.0 5.0 0.0 0.0 0.5
    18. w 416 48 400 48 0
    19. w 400 48 400 80 0
    20. w 400 80 416 80 0
    21. w 400 192 416 192 0
    22. w 416 96 384 96 0
    23. w 384 96 384 208 0
    24. w 384 208 416 208 0
    25. d 368 208 368 160 1 0.805904783
    26. w 368 208 384 208 0
    27. w 368 160 400 160 0
    28. t 352 240 384 240 0 1 0.6841293355018976 0.7280189985849131 100.0
    29. r 304 240 352 240 0 100.0
    30. w 384 208 384 224 0
    31. w 384 272 384 256 0
    32. g 384 272 384 288 0
    33. l 544 64 544 128 0 0.01 0.049950044957540074
    34. r 544 128 544 160 0 100.0
    35. w 544 64 528 64 0
    36. w 544 160 512 160 0
    37. w 512 160 512 32 0
    38. w 480 32 512 32 0
    39. w 480 176 512 176 0
    40. w 512 160 512 176 0
    41. w 528 64 480 64 0
    42. w 480 64 480 144 0
    43. w 144 272 160 272 0
    44. w 400 80 400 160 0
    45. w 400 160 400 192 0
    46. r 128 144 128 208 0 500.0
    47. w 128 208 128 240 0
    48. w 304 208 304 144 0
    49. w 304 144 240 144 0
    50. o 5 64 0 35 1.25 0.00625 0 -1
  7. tsukaranz
    Aug 23, 2011
    24
    elce_mech:
    what if i use a 3v dc motor, what is the transistor to be used??
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The transistor won't change, but if your power supply is only 3v, you won't be able to use a BJT 555 timer, nor a relay.
  9. tsukaranz
    Aug 23, 2011
    24
    can you pls, name me a generic transistor to be used...
    thanks...
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Generically, the circuit uses an NPN transistor to control the relay coil current.
    More specifically, a general purpose 2N2222 transistor should work fine.
    The diode can be a 1N4148/1N914 or a Schottky diode.
    But you still have not told us if you are using a 3v supply for the entire project or not.
    What voltages are you using for the project?
    Are you using batteries? If so, what kind?
    What is the current required by your motor at 3v with no load?
  11. tsukaranz
    Aug 23, 2011
    24
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, perhaps you can use a resistor in series with the motor to limit the current. Otherwise, you'll likely burn it up pretty quickly. Without knowing what the required current is, it'll be kind of difficult to calculate the resistor. Perhaps once you have the motor on hand, you can figure it out by powering it from a couple of AA batteries in series.
  13. elec_mech
    Nov 12, 2008
    1,513
    193
    SgtWookie - I can't say I've done much with motors, but is a 1N914 or 1N4148 going to work better (faster response) or the same as a 1N400X diode? I suggested the 1N4001 because it can handle more current and it is what I have seen on the few motors I've taken apart from other items.
    tsukaranz -
    I don't think you want to apply 5V to a 3V motor. A quick look at RadioShack as a simple guideline shows motors available that run from 1.5 to 3V, then they jump to 6V. This suggests your motor is designed to operate from 1.5-3VDC. Jameco shows some that run from 1-6VDC, but also shows some with a max of 4.5VDC. Running at 5VDC could have it screaming (running too fast) and may result in damage.
    If you're going to use relays to control the motor, I'd suggest using 3VDC for the motor and relay output and 5VDC for everything else. You can use a LM317 adjustable voltage regulator with some resistors to drop your 5VDC down to 3VDC.
    Can you supply 3VDC to the motor now and measure the current draw with a current meter?
  14. tsukaranz
    Aug 23, 2011
    24
    well, i'm not sure if i can get those things at radioshack coz i'm a bit far... i'm from phils.
    by the way elec_mech, thanks for the info...
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I suggested the 1N914/1N4148 for the relay coil diode; as they have very short ON and reverse recovery times. The 1N400x series does not have on and off times specified; if a particular manufacturer's diodes are slow, that could lead to the destruction of the transistor.
    Schottky diodes, such as 1N5817 through 1N5819 could be used; they switch on pretty quickly and have very low reverse recovery times - far faster than standard silicon diodes.
  16. tsukaranz
    Aug 23, 2011
    24
    thanks elec_mech...
    now, ihave an idea...
    i'll be back in a few days, for my circuit..
  17. elec_mech
    Nov 12, 2008
    1,513
    193
    SgtWookie,
    Ah-ha! Sorry, I keep forgetting the transistors are driving the relay coils, not the motor directly. Thank you for the information, I'm sure I'll put that to use in the future.
    tsukaranz,
    I didn't mean you needed to go to RadioShack, I was just using their website as a reference for information since they sell hobby motors similar to the one in your picture.
    Good luck in your circuit.
  18. tsukaranz
    Aug 23, 2011
    24
    thank you... my circuit was done...
    i'll post it later...
  19. tsukaranz
    Aug 23, 2011
    24
    here's my circuit..
    there's one thing i don't understand... why is it that in the square wave, there is small wave after every three waves?? how is it so??
  20. tsukaranz
    Aug 23, 2011
    24
    hey, buddies... if i want to put another IC which is the LM741, how can i use it??
    i was thinking of changing the var resistor into an LDR, and put a sound detector circuit in it that uses LM741, but do i suppose to do it??
