Help with the following 2 questions and to explain how it works
Discussion in 'Homework Help' started by Wjs, Jan 27, 2014.
  1. Wjs
    Jan 27, 2014
    Hi there i saw you guys did have a thread about these 2 questions but didnt finish it i am busy with a subject called foundations of computer science and cant seem to figure out how to do this please help
    Question 1
    Use only Boolean algebra to simplify the Boolean expression F. (First simplify F
    1 and F2, then simplify
    F1 · F2, showing all the steps. You need not provide the names of the Boolean rules that you apply.)
    F1 = x + x'(yw)' + w'y
    F2 = (y' + x')'
    F(x, y, w) = F1 ⋅ F2.
    Question 2
    Use a
    Karnaugh map to find the simplest form of
    H(A, B, C, D) = m1 + m4 + m6 + m7 + m9 + m10 + m12 + m14.
    Derive the terms of H directly from the Karnaugh map without making use of algebraic manipulations
    or truth tables. Clearly show the groupings.
    Use exactly the same order for the variables as given in the following diagram:
    CB AD
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Question 1: Simplify F1. Then, simplify F2. Then, combine them and simplify that expression.
    Post your work and we can help you where you may falter.
    Question 2: m1 = A'B'C'D. Use this methodology to fill out a Karnaugh map, and minimize H. Note the rearrangement if the variables, so you will need to rearrange variables for your answer.
    Again, post your work and we will try to help you.
