Help with television cooling fan
Discussion in 'General Electronics Chat' started by blaubne, Dec 26, 2008.
  1. blaubne
    Dec 26, 2008
    Hey everyone I have a quick question. The cooling fan on my samsung television stopped working abruptly last week. I fixed the problem but don't know which way the fan was facing originally. Do cooling fans typically draw hot air out of a television, or do they blow cool air into the television. Thanks for your help
    B
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I didn't even know tv's had cooling fans.
    Look at the dust on interior components. If it's on the side facing the fan, then the fan blew in. Otherwise, it pulled air out.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I liked that advice, it will get you there. If for whatever reason you still have problems think airflow, hot air rises, the fan helps the flow go where it wants to go anyhow.
  4. Napoleon
    Dec 21, 2008
    45
    Typically the fan will blow into the cabinet and onto the light bulb, if this is a projection TV.
    But yes, look at the dust pattern to get an indication of the air flow direction.
  5. blaubne
    Dec 26, 2008
    Thanks for your advice. I'll bump this thread up if I have any more problems.
